Looks like you have the Williams wiring correct above. The voltage adjustment needs to take place after you install the Williams sensor in the OEM bellcrank. Just back off on the idle stop screw until you get a suitably low voltage. I couldn't get mine to go lower than . 634 volts. As to how the wiring attaches to the sensor I now see the confusion there. There is a Weather Pack 6 pin connector from the harness into the sensor. This harness is about 2' long and has a 6 pin connector on one end and two 3 pin connectors on the other. The photo should clear that issue. You also asked why you need a jumper if you were to clip off the two weather packs and install a Deutsch connector. You don't... your way would work perfect. I'm going to make up a few jumpers so folks don't have to clip or fabricate anything. . but it can be done the way you describe.
Just to clarify the photo's. . they show the Williams sensor attached to the pedal assemby and the 6 pin weather pack unplugged from the sensor. The last photo is where the jumpr would go between the weather packs (2) and OEM connector. Hope this helps
Also I agree whole heartedly with the posts above about the experimental nature of what we're doing here. We're all beta testers and need to be sure this stuff stands the test of time.
Mike
I seem to have made a mistake in the above post. The 6 pin connector that plugs into the Williams APPS is not your garden variety 6 pin Weather Pack. At least not what I can find online or at the local NAPA auto parts. It looks like this is the correct harness: 130063 Wire Harness
If it. . is it will have the 6 pin connector on one end and the 2 Weather Packs on the other. Anyone who has ordered this harness might want to confirm if it's the right one or not. Aslo, does anyone know who makes that 6 pin connector. It sorta looks like a weather pack but I haven't located one as a stand alone purchase.
Mike
