BoeingDiesel
My 99', for the past few days, has been getting harder to start when it's hot. Never once in the 268K miles has this happened before and no matter if it was hot or dead cold it fired up after a couple cranks. Fuel pressure is 13 at idle and under a heavy load will drop to 10 psi. I have a Watts fuel regulator on the feed line to the VP and it's set to a max of 13 psi. Not trusting the Isspro I checked the fuel pres. with a mechanical gauge and it read the same. I called Cummins Cal Pacific and ordered a return line check valve thinking that may be the cause. I'm reasonably sure, after doing a bleed on a tee fitting that I have just before the IP that isn't the problem. Any ideas, or suggestions is greatly appreciated.
99' 2500 SLT QC 2WD AT Airdog 100 Isspro Gauges DTT Filter PDR HX35TC 268k miles
2006' H. O. 6spd. 3500 QC 4x4 SLT.
