GREAT we're getting a good picture now! Thanks for all your tests! I know it's time consuming...
Let's see if I'm getting it correctly.
The rattle seems to be related to the fact that taller than stock injectors are used in 03-04 engines. Let's assume they already advance the timing a little on their own.
1) Smarty ALONE using softwares without increased timing = no rattle. ( Even #'s)
2) Smarty ALONE using softwares with increased timing = rattle only at high RPM's.
3)Add TST at any level to Smarty = rattle.
Correct?
Just one ( more ) stupid question, you don't have a Rocktech ( Sp? ) sensor on the trucks? Just to make sure... .
Smarty's timing alone does " rattle " a little @ high RPM's. That's where I have increased the timing most, or better where the stock timing is waaaayyyy retarded. In this case what you call rattle, I spell it performance.
I believe you hear it due to the fact that the CR is so quiet. On the previous engines you would not have heard it. Fact is, diesel engines DO rattle a little with a correct timing. In fact driverno8 sez :
OK, went out and loaded #6. Feels good. Not as
peppy as #7.
Sure, the "less peppy" thing is due to the less ( stock ) timing...
But let's see the real concern, the fact that the TST added to Smarty rattles even with a stock timing, while it SHOULD not.
Hmmmm, let me tinker a little about it. I'm starting to see a light...
Driverno8, would you be willing to test a few variations of let's say software # 6. I'd need to send you another update for your Smarty with modified softwares. You test them... .
Thanks!
Marco
