Yup...
I tried a B&M kit in my T/A a number of years ago. Lots of folks on here use them without problems but I had a few so I do it differently now.
IF you can weld (wirefeed is easiest or use a 6013 1/8" rod), go to a NAPA store (others should have these as well) and get a 1/2-20 nut (fine thread) and a 1/2-20 drain plug with a magnet in it to help trap metal. The pan already has that big magnet in it but more is better. Be sure and get a drain plug as that will come with a gasket.
Drill a 17/32 hole in the pan, put the nut on the inside and thead the bolt into the nut. Make sure the seal is removed or, better yet, use a different bolt. Tighten it down so the pan is sanwiched between the nut and bolt. At this point, go on the inside and weld the nut to the pan. Let it cool completely and then remove the bolt. Touch up the paint on the outside of the pan and your good to go.
Be sure that you don't catch the bolt with the welder or you'll have fun getting the bolt out of the nut to install the seal. This won't get all the oil out, you'll have a little left in the pan but it's a lot nicer than no drain.
