2nd Gen Non-Engine/Transmission Bad Power Distribution (Fuse Panel)?
Engine/Transmission (1998.5 - 2002) valve adjustment
Engine/Transmission (1998.5 - 2002) alternator brushes, bosch
BigPapa
The fuse panel under the hood of my '98 24V is having a problem. If you move any of the fuses on the front row front to back I lose all power. Anyone had this problem? Friend of mine says it is the contacts in the panel for the fuses. Is it repairable or do I just need a new fuse panel?
Also need an oil pressure sending unit for a '98 24V if someone has one.
Thanks,
Scott
Scott,
There's a large multi-pin connector under the PDC. I've heard the fastener that holds it in place can fail (strip I think) causing the connector to loosen.
You might check that and also look for corrosion or loose contacts.
Good luck,
John L.
