Ball Joint replacement follow-up!
Taking apart the dash panels
HELP!,check engine light after new DDII's.
Folks, many of you may recall that at 4k I had a ball joint go bad. The dealer replaced it with a complete lower control arm/ball joint. Then at 9k, same problem, same side, this time it was the replaced lower control arm/ball joint! I began to think I was looking at visiting the dealer every 4 or 5k miles for new ball joints. Instead, the tech put in a grease zerk! Interestingly, he didn't drill far enough into the ball joint so the noise continued. That's when he thought the upper ball joint was the noisy one! :eek: Well, after he and another tech worked to figure out what was going on, he drilled just a tad more and voila! Now, thanks to the dealership, the left upper and lower ball joints have grease fittings!:D Now all I gotta do is wait till the right side ball joints fail. :rolleyes:
