Off Roading biggest tire on 16.5X975
Competition DHRA rules
Competition New drive-shaft loops pics.....
I have a 2" leveling kit, right now on there are some 33X12. 5X16. 5 ugly all terrains i forget the brand, but i have a lot of room, like at least 3 inches when turned at the closest point, they look small, but whats the biggest tire i could fit, size wise, i'm looing into 33X14's or a 315 anyone know how bit that tire is, thanks
Aaron
'bout the only thing your going to find in 16. 5 are either some 33x12. 50's or 35x12. 50's. Those are gonna be all terrain most likely too, but BFG makes both A/T & M/T.
Also a lot of off-road tire manufacturers like Interco (Super Swamper's) and Denman (Ground Hawg's) make wide tires in 16. 5's but they won't last as long as a good A/T.
If you want my personal advice, get away from 16. 5's. My truck unfortunately came with them, and I stupidly didn't go down to 16's whenI bought wheels cause my tires were still fairly new... ...
That was 3 years ago and 16. 5's are getting harder to find for a good A/T Terrain every year. BFG's usually cost the most. I'm going with some 16x10's soon and some Mastercraft Courser C/T's (an aggressive A/T tire). Right now I'm running Mastercraft Courser A/T's because they were cheaper, but also have a decent A/T Tread. IMO lose the 16. 5's. :rolleyes:
i'm in the same boat you were in, truck came with them, right now i'm just looking for a decent mud tire, so i can go play sometimes, the at's just don't do the job, i did find some super swamper boggers, 33x14x16. 5 that i could use, i was thinkinga bout those, but its so hard to find a decent looking rim, that is 8 lug that you don't have to special order,
I guess this really won't help since my rims are 16's (I did not know our trucks came with 16. 5's). However, I have the 2. 5-inch leveling kit and have been very happy with the BFG 35x12. 5 MT's. I do have some very slight rubbing on the passenger side lower link arm at full lock.
I didn't buy my truck brand new, someone put aftermarket 16. 5's on it, so to answer your question you were right our trucks didn't come with 16. 5's, but u fit 35's with just a leveling kit?
i should be find with the 33's i want then haha
Yeah same boat, someone installed 16. 5's on my truck. I snagged a set of 01. 5 Alloys with STILL NEW Michelins(sp?) for $400 when I got the truck but didn't know about having to clearance the drums and didn't want to so I sold them for $350 DOH!
You will be able to fit 33's with minimal rubbing during articulation. On the street they shouldn't rub, mine didn't.
I WOULD NOT put Boggers on this truck if it is your only mode of transportation. They will wear out EXTREMELY quickly and you'll just end up out major $$$.
Get you some BFG M/T's and you'll be happy. Have a buddy up north who's getting like 40K I think outta them. He balances and rotates them regularly and makes sure the psi is right though. That's the key to good mileage.
With a 2"-2. 5" lift you can clear 35's with minimal rubbing. I've got the skyjacker 2. 5" coils already in the front of my truck for when I get 315's (metric 35") next go around.
well this isn't my only mode of transportation, and i don't drive much, the last car i had for a year and i put a total of 6k miles, and that was going to sac many times, which is like 100 miles away, and to the bay area which is about the same. anyways, i don't drive much, what tires are good for pulling also? bfg muds any good for that? I wouldn't mind them but they don't coem wide enough, i don't like the skinny tire look, they only come about 12. 5's which is what i have, and it loks funny but o well, how wide are the 315X. . X16's
Well about all you are going to find in a radial tire is 12. 50 wide.
You could look into off-road tires like Super Swampers, or Ground Hawgs tires like that for the extra width. Personally a 12. 50 wide tire on a 10" wide rim looks pretty wide. However everybodies opinion varies.
315 75 16 are almost identicle to 35 12. 50 16. 5 in diameter and width. I have the 2" springs and run 315's without any problem. :)
I think i'm just gonna get a 33x15. 5x16. 5 super swamper tsl/sx a friend of mine had those on his yukon, lasted quite a while with no signs of wear and look really good too, another question, who makes good lifts for our truck, the biggest i have found is like 5 inches, and that isnt'[ that big to me, today i saw an all white, 2500 long bed ext cab, had to be about a 10" with 38's, it was big, diesel of course, but looked relaly good, any ideas?
go over to www.pavementsucks.com they have a lot of way up HIGH CTD's over there. The norm on there's are 38's! :eek:
Most are running the 4. 5" kit with spacers on top of the coils. If you join up and do some searching however I remember not to long ago they said Skyjacker makes some 7" lift coils!!! :eek:
