I was driving just a short time ago... . but now am on the side of the road:{
Heard a loud pop while climbing a hill then coasted to a stop on the other side. Thought I had blown a hose but no. Took off the afe and found there to be mucho end play on the compressor shaft probably an inch. Removed the hose I thought I had blown and it is full of oil. In fact right before I shut her down white smoke was starting to boil out of the exhaust as well as the oil pan vent hose.
So I have a friend on his way to tow me out of here but not sure what to do from there. I still have my factory turbo so I could put that back on but I'm guessing it is a bad idea to just fire it back up after that. Should I take the intercooler out and attempt to clean the oil out of it along with the associated lines? How do you recommend you clean that out? Do I need to remove the head or should I just run it? The comprsoor blades are worn way down easily a half inch of them are missing. What do ya think that will have done to the motor?
What to do?????
What to do?????
