Engine/Transmission (1998.5 - 2002) Boost/EGT
2nd Gen Non-Engine/Transmission Rear Axle Swap Q?
Boost gauge starting fluttering under load yesterday. Would flutter between 10 adn 15 psi real fast. Also EGT gauge is all over the place. Could these be related to a ground or ?
Depends on your gauges, electrical or mechanical. What type of gauges do you have and are they a manual read or electronic???
Fill out your signature in User Control Panel so we can see what truck you have and any mods.
Genos carries some of the replacement senders\probes but not sure which ones. Give them a call and they will know what to do or find you a solution.
