Boost gauge questions
Not mechanical in nature but anyway..................
Intake Tube Upgrade
I drilled a hole in the throttle bracket and put my boost gauge in the manifold above that area, removed a pipe plug and put the fitting in. I see some turbos with a gauge tap right on them. Would boost pressure readings be different closer to the turbo or on the outlet flange compared to at the intake manifold etc?
I would think that as long as the IC has no leaks, the pressure would be the same on either end... . but have never heard this discussed. I used the plug on the manifold for mine.
Don't know..... 2 or 3 psi I believe it is. It's refered to as a pressure differential in case you were wondering... ... ... ... ... ... ... ... ... . :rolleyes:
You want your boost readings at the manifold, that way you can tell if you get a leak between the turbo and the manifold. After all what matters is the pressure at the manifold.
HTML:
Yes this is correct.
Scott is also correct about the pressure drop... at least in an IC engine.
Not so sure about in a non IC engine since the crossover tube is so short and straight.
Heat will also affect the pressure... again more reason for the "drop" with an intercooler.
