While tearing down the '91 Cummins from the donor truck I found 4 broken exhaust manifold bolts. To make matters worse, the previous owner tried to drill the two upper bolts and made things, well, much worse.
I believe that I can remove the 2 lower bolts, but does any one have suggestions for the upper two?
Right now I think I'll have to pull the head and put it in a mill to fix it. (fill the holes, then redrill and tap)
Also, the manifold appeared to be "short", like it had shrunk. With the other 8 manifold bolts in place, the 5th and 6th manifold ports didn't line up, like the manifold was 1/8"-1/4" too short. Is this normal? Could this be what broke the bolts for the previous owner?
