Hello all,
My 1996 Dodge 3500 4x4 exhibited oil in the coolant. I replaced the head gasket and had the head checked, flatened and a valve job done. After reinstalling head I still had oil in coolant, only this time I had water in coolant also. Removed head again and also removed oil cooler. Took oil cooler to Cummins and had them check it for leaks. They found no leaks, reinstalled oil cooler with new gaskets. Found that I had damaged head gasket while reinstalling head. Replaced head gasket again, only this time I placed the head on the block with no gasket installed then raised it straight up and carefully slid gasket under head and placed head straight back down. After getting it running again was getting alot of pressure out of the overflow tube into the overflow bottle. Shut engine down and check oil level. Level was right where I had placed it. engine had run for about an hour during this process. Started back up this morning (1/22) to flush radiator some more. Checked oil level again and had water in the oil again. Just a note, I have used only Cummins parts. I have come to the decision to replace the engine. I am working on a limited budget just like everyone else. I have done several other things such as KDP repair and installed (I know) Banks Git Kit. Also had a clutch installed approximately 3 months before first head gasket replacement and had only put about 200 miles on it. After replacing head gasket the first time I drove it some and as soon as I started driving it the clutch started squalling. Took back to the guy who had installed it and explained the situation and he charged me an additional $750. 00 on top of the $900. 00 he charged me the first time he replaced the clutch. Upon asking what happened to previous clutch I was advised that the pressure plate springs had fell out of the plate. Needless to say I will never use him again for any repairs what so ever. I guess you can feel my frustration with all of this. I love this truck and use it to pull my 37'6" travel trailer (Even though it has been broken down since I have owned this trailer). The reason I am writing this (sorry if it is to long) is to ask if you guys can help me find an engine that I can install back in this great truck and hopefully get it back up and running? I have contacted Cummins and they have given me a price of $7,815 and some cents for a reman. My truck has 139,000 on it and this problem has destroyed me because I counted on this truck to last me at least a half million miles.
Thanks for lending an ear and I would appreciate any help anyone can give.
I am friends with Big Poppa and he is also on the case.
