Just noticed while rotating the tires that I have the 3. 5mm wheel spacer on the right front. I searched and found threads that explained that it was either to stop pull to the left on braking or to even out the wheels because of the offset axle. This thing pulls to the left (on braking) and I could care less about the offset issue. It bothers me that the rim doesn't sit on the hub/the lug nuts don't tighten as far on the stud as they should.
My only concern is will this affect my alignment to any significance if I pull it out? I just had this thing aligned about 5k/6 months ago.
Thanks in advance.
Thanks in advance.
