Had new 18" ceramic tile installed in the kitchen, half-bath and utility room. The cost was substantial. Install was done by a self-employed independent contractor for the company where I bought the tile. This company has a good reputation and the sales person is reputable to my knowledge. While installing new baseboards, I laid a hammer down on a tile and heard a hollow sound. Well, 17 of the tiles (probably about a fifth of the total) appear to have a void between the bottom of the tile and the thin set (guess that is what they use under the tile). When tapped with a tablespoon, a distinct hollow sound comes from portions of the 17 tiles in question. After I found the first "hollow" tile I called the company and they agreed to replace that tile and I had no problem with that at the time. However, I then checked and found the other problem tiles
Questions:
1. Do I have a problem? The fella who installed it told me the tile would never crack, but it is obvious he doesn't want to come back on a job he's already been paid for.
2. Should I insist that the 17 tiles with a hollow sound, indicating a void be replaced? Install was two weeks ago so they should be able to get tile from the same dye lot.
3. Should I insist that the entire floor be removed and replaced? If they replace such a large percentage (the 17 at issue), appears we could have a problem matching all the grout lines and generally weakening or even chipping the tiles adjacent to the ones with a void when they are removed.
Thanks in advance to anyone who can give me some input.
Questions:
