Here’s how I did it.
Bought the tires/wheels on ebay…got a set of 5 for $725. New hummer buyers seem to be just throwing these away…. . they’d cost over $2K from a dealer. The tires alone will run at best $130 a piece…. that’s assuming you have 17” wheels to mount them on…and live next to the warehouse you’re buying the tires from…. shipping can be a killer.
Anyway here goes.
Bolt pattern is spot on…no mod required. Two modifications that are of concern.
Center hub hole diameter. The stock H2 wheels measure 4. 58”…where our second gen trucks measure 4. 75”. That comes down to (4. 75-4. 58)/2 = . 085 of metal to remove from inside of hub hole.
Centercaps…. . the stock H2 caps fit the front…but the rear axle hub won’t let them fit. You could cut a hole in the H2 caps to make them work on the rear hubs and you’re off and running. The H2 caps look OK…buy they’re kinda like ladies underwear…they might feel good but you don’t want your Dodge buddies catching you using them J. So you need to do some trimming of the stock centercaps to get them to fit the new wheels.
Anyway here goes.
