DJW said:maybe DC will have to retrofix, plus pay for vehicle lose of use, if required to fix same.
:-laf :-laf :-laf
I'll be wearing my raincoat that day ! There will alot of pig **** falling from the skies that day.
Fireman
txhawg said:First of all, I have never been offended by a nipple, and second, I don't think she will let me do that.
RichardTaylor said:I have a 03 ctd and the nipple on my tank is the opposit of all of yours! Mine is not recessed but is instead raised up on a dome so everything will roll off instead of puddling, I also do not have a hose attached.
WOT said:Someone had mentioned just connecting the two vents. If I did this how would air get back into the sysem as the fuel was used up?
BApple said:I have a 04. 5 and the nipple is on a domed area and not a recessed area like the pics in this thread show. Nevertheless, I am going to put some fuel line hose on the nipple just for a piece of mind.![]()
DZink24 said:Not for nothin, but in the event of a rollover crash, wouldnt this genious setup cause the tank to leak? Not so big a deal for a diesel, but couldn't this get hairy for the fire department if it were a hemi under the hood? Lastly, I have read the many posts here, and I just want to make sure I am reading correctly- There are 2 small openings in the top of the tank that should have at minimum, 6" of 1/4" fuel line attached to them, to help to keep road grime and H2O out of the fuel?
DZink24 said:There are 2 small openings in the top of the tank that should have at minimum, 6" of 1/4" fuel line attached to them, to help to keep road grime and H2O out of the fuel?
rbattelle said:Pretty much. Might be a good idea to slap a little inline fuel filter on the ends of the hoses to keep even more grime out.
-Ryan
Spooled-up said:When you connect the 2 vents, you need to use a small fuel filter from a volkswagen. From what I understand, it connects the 2 lines and allows air into the tank.
