Has any one seen a 12 valve head crack on the outside between the exhaust port and the injector? It is about 1/2" long and only seems to leak a little when cold. There is no water in the oil and its does not loose any water so it has to be loosing a very little. I just got this truck on the road and the head has quit a bit of money in it, so I would like to keep running it if its just a casting flaw. I inspected very closely between the intake and exhaust valves and did not see any cracks.
The other question is if I do need to change it. Can you put a 24 valve head on a 12 valve block? Do they flow better and crack less? I know I will have to get custom lines but what about the injectors?
Any input would be great.
Jon T
Jon T
