Originally posted by DEZLPWR
It is on the driver's side front lower corner of the block in pretty big numbers. (1"?) Look right above where the oil pan is connected to the engine. You can only see it from under the truck, and it is slightly in front of the power steering pump.....
Let me know if you still can't find it.![]()
Dezlpwr
I looked at mine this morning and there is no numbers, unless they are underneath the wiring bundle that runs along the bottom of the block. It is strapped on so I could not move it to look under to see any numbers. Mine is not an early 24 valve. It is a 2000 that was manufactured in November of 1999. If you have any Vin numbers that would help the ID. I did look every where for the numbers, from the power steering pump to the front of the block. Even tried to see some thing from the rear of the engine and no numbers???
