Engine/Transmission (1994 - 1998) Dana 70 tore up - need replacement
Engine/Transmission (1998.5 - 2002) turbo advice
Engine/Transmission (1998.5 - 2002) Raptor 100 Install question
Folks,
I have a 98 12v 2wd auto with a bad rear end. Will a Dana 80 from a 2002 2500 CTD 4wd swap in?
Thanks,
Jim
Yes but... . you'll need the u-bolt brackets from the 80 and you'll probably need to have your driveline lengthened about an inch.
-Scott
Hi Jim:
Yes, however you will need u-bolts plates for a Dana 80. Since you are going from disc on the front to disc on front & rear, you need to compare the two master cylinder. Also, you may need to shorten the drive shaft.
P. S. I am in the middle of replacing my Dana 70 in my 1997 with a Dana 80 from a 2001.
I'm in Athens GA. PM me about the 70 - condition, cost etc
If I get the 80, can I use the existing proportioning valve or would I need one from a disc/disc set up? What's the difference in the master cylinders from the disc/drum on the current 70 vs disc/disc of the 80?
