Dash Question
Ball Joint Press
Replacing steel lines
The bezel just pry's off. The entire thing goes around the radio and heater controls. It is held in there with clips.
If it is like my '06 Mega there are 2 screws that you have to deal with the first time you take the bezel off.
If you have the small floor console that has to come off, then the bottom center of the dash. The screws are then accessible.
The first time you take the center bezel off it will scare you to death because those clips have a firm grip.
Thank You... probably have to pull the center out... I am trying to find a clean way to mount a CB in the dash so it doesnt get kicked and re-adjusted... my dog likes to sit on the center console
I removed mine to install a double din DVD player and did not put these screws back. I have easy access to the radio if I need to get to it.
Yes, I should have added the fact that I did not put the screws back in mine, either.
The panel stays in place just fine without the screws.
Mike. :)
