Engine/Transmission (1998.5 - 2002) DDRP (FASS Fuel Pump) Installartion: Part II
2nd Gen Non-Engine/Transmission cool blue hose for 2nd gen?
1998. 5 Dodge 2500 Quad Cab, 4x4, 5 Speed NV4500 Manual Transmission, Generally Stock Equipped
Gentlemen:
I have been driving my truck since early February with the direct replacement lift pump from FASS. I installed a stronger spring to increase fuel pressure and that has worked: The truck runs at about 17 psi at idle, 16 psi at cruise and about 14. 5-15 psi at wide open throttle. So far, so good.
I indicated in one of my last posts that my truck would sometimes not start after one click of the key--my gold standard for starting performance. Sometimes it would take and extra second or two... possibly three seconds... before the truck started.
I decided to drive the truck for awhile to see if I could establish a pattern. After several months, this pattern has emerged: Upon initial startup after say an overnight shutdown or a shutdown lasting several hours, the engine fires with one brief touch of the key/starter. However, if I am doing a number of errands, the engine will cranks for several seconds before it fires. It does not matter what position the truck is parked. It does not matter what altitude that the truck is operating at. It does not matter if the truck has been driven for hours or just a few minutes. The only thing that seems to determine starting performance is the time interval between shutdown and start-up---the longer the better. I think that it returns to its quick starting self after about a couple of hours of non-operation.
Any ideas? I have not approached the FASS people yet on the topic. Could it be an indication of injector pump issues? Heat related? Computer? I have no signs of trouble. The engine always does start. No trouble codes either.
Thank you in advance.
M. Young
Fair Oaks, CA
It sounds like the fuel pressure might be too high. I would suggest you return the DDrp to it's stock condition and see how the truck starts.
About six months before I got couple cases of dead pedal and 216 code, I started having longer crank times with a warm engine in the SW hot weather. Is this related to hot weather? After a new VP44 from MWFI, engine again has always started with a quick turn and release of the key.
SNOKING
FYI: The truck started fine with a weaker spring but I had Carter style lift pump fuel pressures. I may go back to the weaker spring if I see no other suggestions.
I always remain concerned about the health of the VP44.
Thank you again.
M. Young
