DEF System Malfunction
High Pressure Fuel Pump Failure at 3,800 miles
4 wheel does not engage
I recently had a rather "interesting" commute between four dealerships in three days to limp my 2016 3500 single rear wheel short bed with the P20E8 error one thousand miles to a dealer where I needed to be anyway, which was only successful due to a few very helpful suggestions here. It seems that there are a few things one must know as an owner of these trucks, and this is definitely one of them. There were some comments regarding making a "sticky" for this issue since it is a common occurrence. I do not know how to do that, but hopefully this helps someone else.
Situation: You are driving and the EVIC shows the dreaded "Service DEF See Dealer" message.
- If this is a new issue, you should get a 150 mile countdown until your vehicle is crippled. If you need to drive significantly less than that to get to your destination, no problem. Go where you planned to go, within reason (it might not be a good time to go off-roading or to a very rural campground with no cell phone service), and then seriously plan your next moves. This will most certainly involve visiting one or more dealerships.
- If you need to drive significantly more than 150 miles, you must plan in advance (at least somewhat). There are three actions that will cause your vehicle to be crippled and governed to 5 miles per hour maximum once that countdown has elapsed: fueling the vehicle, idling for more than one hour, and shutting off the engine. Your strategy should be as follows:
- Get some good rest if you can, you will need it.
- Plan to arrive at a dealership within the range of one tank of fuel with at least a few hours before their service department closes. I also tried to avoid rush hour traffic due to the "long idle" restriction.
- Fuel up just before the countdown hits zero miles. Once it hits zero the message changes to "5 MPH Max Speed on Restart, Long Idle or Refuel". Once you see this message absolutely do not shut the engine off.
- Drive continuously on that tank of fuel directly to the dealership. Some have suggested that you can fill the tank with small amounts of fuel (a 5 gallon can at a time) without triggering the 5 MPH limit. I did not have the testicular fortitude to try it out and potentially need to wait hours for a tow, not arrive at the dealership on time, and extend the trip by yet another day.
- Have the PCM (Powertrain Control Module) re-flashed. This resets the 150 mile countdown and all of the diagnostic trouble codes. Just resetting the diagnostic trouble codes does not reset the countdown. It cost me between $200-300 each time for them to do this (some dealerships, against my specific instructions, did other things too - like regenerating the diesel particulate filter), and until they "prove that the error is caused by a defect in a part under warranty" you will be stuck for the bill. Supposedly, once it is proven that there is a defect under warranty you can argue to get reimbursed for these bills. I have not had any success yet.
- Repeat this process until you get to your destination.​
Common issues that cause this problem (from easy to near impossible to fix):
- Running out of DEF.
Fill the tank, drive a bit, and the error should go away but your 150 mile countdown will not reset. If the error occurs again you will be starting at whatever mileage was left before. If this does not fix the problem you may have to re-prime/ flush the pump, which can be done with a (dealer) professional-level scan tool (the process is called the "DEF Reductant Doser Pump Override Test", located under "Systems Tests", but if you have spent many thousands of dollars on the scan tool that does this you should probably know this already). I have not found a scan tool under $1,000 that can do this, and I have not considered purchasing anything more expensive than that, but please comment here if you find one.
- Clogged DEF injector or supply tube.
This can some times be cleared by just re-priming/ flushing the pump as above. Other times, it requires removal of the injector and/ or supply tube and a good cleaning.
- Faulty DEF injector.
This is apparently a relatively quick repair, unless a bolt is stuck and breaks off in the exhaust pipe.​
- Poor choice of DEF, contamination, or other issues.
This might just require draining and refilling the DEF tank followed by a re-prime/ flush, or it may have destroyed some other component(s) in the process.
- Bad DEF pump.
This is the most dreaded of the problems, as it may not (as of 10/29/2020) be able to be fixed.​
As many may be aware, new DEF pumps cannot currently be obtained. If a dealer has one in stock, it may have the same issues as the pump that just failed. In my particular case, my truck has been in the shop for about 1.5 weeks now. The dealer found a new pump that was in stock at another dealer literally on the other side of the country, installed it, and upon testing it the new pump was already dead. Now the dealer has supposedly located a second new pump. We are awaiting shipping, but I am concerned that it may suffer the same fate. In my case this truck was new-to-me five months ago, and I have been driving about 2-3k miles per month in it without any issues, until now. I have always used Blue DEF and never let the DEF tank go empty, but I have no idea what the service history was on the truck from the original dealership through 32k miles. The service tech at a dealership has said that FCA is redesigning the pump since so many have failed and a new one should be available by May. Unfortunately, another service tech at a different dealership had advised that if the problem was a DEF pump that the best fix was to "Trade it in and get another truck." At that dealership it was reported to me that they had four disabled trucks on their lot and no spare parts they could obtain to fix them.
Thanks for the great write up.
I'm sure as it becomes more common maybe there will be aftermarket EPA approved parts.
There was a huge thread about the concentration level of the Urea in the DEF that is pretty toxic to the parts.
There could be some specific year to year differences if anyone knows of stuff like that to add in.
Do they rebuild these DEF pumps and then when you get warranty work you are not actually getting a NEW one but a refurb? thats what they gave me when my radio unit went Tango Uniform. I would have preferred NEW! But these days any part that can be "refurbished" is what they will give you on a warranty repair. Hopefully the DEF pumps you actually get NEW.
That is a good question, but I do not have a definite answer. It was reported to me as new, but for a new part to immediately fail when they test drove it sounds very unusual. That would make more sense if it was refurbished.
WHAT is the deal with ram and unavailable parts? my clutch hydo unit ( 30 days unavailable ), the def pump in above story, and the 2019 pumps etc. this is crazy. c'mon ram!
Apparently, per our local dealership, COVID has taken a toll on the whole supply chain, impacting not only availability of parts, but of new vehicle inventory, too....
A new pump that failed has me thinking it isn't a pump problem but wiring or controller that is bad.
That definitely makes sense. Electrical gremlins do seem to be present in my truck (backup camera works fine but displays the "camera system unavailable" error, etc.). I would not be surprised if you wind up being correct in the end.
Generally speaking, if there is a Re-Man program for a component there would be a core charge.
This is a warranty repair, so I know nothing about the money end of things.
RudolphB. Thank you for the detailed post above. I have gotten that message twice in the past 14 months. First time was a new DEF pump (Sep ‘19), second time was a new DEF injector (Oct ‘20). Both repairs were covered by Maxcare extended warranty on my ‘16 2500, but the inconvenience/disruption was substantial.
First occurrence was a month after the truck had been parked for 10 months in the car port while I was out of the country, driven 10 or so miles every 4-6 weeks. DEF was full when I left/got back. Second occurrence, truck was in regular use (14K miles a year) and I had completed 67.5K service, 6 weeks prior. After first occurrence I quit using Walmart Supertech DEF and went to just Blue DEF.
I love this truck...my second favorite CTD (after my ‘03), but when I get that message I have pleasant visions of it catching fire in a ditch...but then thoughts of a new truck payment snap me back into reality.
I hope the problem(s) are now solved and I never see that message again!!
As far as I know Ram is still pumping out trucks in Mexico , so obviously there are DEF pumps available. Its just FCA has decided selling a new truck to a new customer is much more important then fixing the crap thats already been built.
Hopefully the final update in my case:
It took about a month and two new DEF pumps (I'm not sure if they actually installed the second new one or figured out the actual problem before its installation, but I know they ordered the second one when I had called them and asked if it was possible that it was a wiring and/ or computer problem).
It was the DEF system wiring harness. Somehow there was a short to ground in the DEF pressure sensor wiring, causing the "reductant pressure low" warning despite this likely not being the case.
All it takes is a tech willing to do the proper diagnosis to find the core issue and resolve it. Hit or miss finding a tech like that at a dealer these days.
Comrade! Haven’t you been paying attention to the global shutdown? I’ve been fighting marine parts back orders since April and the situation has only gotten worse. Ram isn’t immune from global forces. This is yet another reason to bring more manufacturing back to the USA!!!
Along those same lines of thought.....we really do need a remanufacturing service for def components considering the ridiculous cost of the parts!
