KLockliear said:How do you figure DF?
Matt400 said:Is it a bad thing to control boost with fueling?
KLockliear said:Then I guess it depends on how much boost it will make then? My truck is 510+rwhp and makes 37-38psi with it. Cord's truck is 539rwhp and makes 36-37psi (he has a cam). I don't know how much power it would take to get to 50psi, but I'd imagine it would be up there a bit.
tomeygun said:As long as the graph is somewhat linear - You could hit 50 psi with 750-ish HP
AND as long as your truck is not high on EGT with the 37 psi boost, then heck, what more can you ask for?![]()
DieselB59 said:I have had mine for about two weeks now, but just put it in on Saturday. I've gotta say that it is pretty darn good. I had a first run HX40 on my old 12 valve and this is WAY better than the 40 was on the 12 valver. I can see around 30 psi boost, egts are a wee bit higher, but nothing excessive, cool down before I shut her off happens much faster, I haven't gained nor lost any MPG, and the sound of it is definitely unique. In my honest opinion, the turbocharger was well worth its price, and the price of the new PacBrake I installed in place of my turbo mount PacBrake, and the trouble of removing my entire exhaust and re-working it to make the inline PacBrake happen.
LennyReed said:I drove one at 550 RWHP and it spooled quicker than I ever would have expected. Unfortunatly I did get one that had machining issues but hay blowing up turbos is kinda fun when it only costs time, NO valves, NO intercooler,NO money for a replacement. We dynoed it then drove it on the street max boost was 39 psi egt was a ok and power was strong from 1500 rpm to 3500 rpm. Although there are turbos to compare it to the HX-40 isen't even in the same game. The need for a wastegate well, that theroy is BS the drive psi is lower than the boost psi, so I ask why the wastegate? Not the the brochure BS I constantly read but a real tested in the truck for instance... I dont belive the jammer was supposed to be a direct competitor for the BLOW 52 but more for the guy up to 600HP, I can personally state that it works well to 550HP, and agin even when it did fail I had no wheel parts go into the engine it still spun freely and best of all I get a new one for free... Yes free oh did I mention free. . NOCHARGE
Ive tested alot of turbos and found some real junk with no mention to anyone but more for the quest for the knowledge. This turbo is good.
