was stock when i got the engine, now it has the top 1/2 of my 184 pump because it had a throttle return spring built in, i gutted the afc and plugged the boost line, 3200 spring, resealed the pump, and put in new cam plate, rollers,piston return springs, and dv springs. and cranked it up alot. i want it to last a while
also switched the ksb housing and valve the 103 valve was frozen.
