Disappearing Voltage, not charging
Not cranking...
LEAK DOWN RATE TEST RESULTS
Most auto parts stores can test alternators, I would take it back to where you bought it and confirm it is good.
If the engine is running and there is not 12vdc on the blue wire I am starting to question the PCM unless the wiring to the alternator is shorted. A quick check of that you should have already done during the stepped tests. Does your tach work showing that the crank sensor is good ?. I have not found where the PCM gets it's 12vdc from yet other than the truck must be running.
