TPCDrafting said:Moo, Have you tried tightening down the oil fittings yourself? Sometimes them fittings can loosen up, especially if you have been "running it hard". It probably took longer to take the pictures of your oil drippings than it would have to tighten down the fittings and wipe up the mess.
Did you ask before purchasing if you were getting mandrel bent plumbing? Most twin setups I've seen are welded, although I haven't been around all that many sets. I would hope that you have learned to be a more informed consumer from this and I do hope you realize you were getting in on a new product line as I recollect you bragging up that your serial number was 1,2 or 3, and the tribulations that come along with that.
What has been your experience of calling or dropping by in person with Bob and/or DTT? E-mail is a handy form of communication, but the least personable and many people don't use it very well. Try sending an e-mail to Piers as opposed to calling him, you'll get very different results. No offense to Piers, but he's a very busy person (as is Bob) and doesn't use e-mail or this forum all that often. But give him a call on the phone and you will be overwhelmed with the knowledge he freely shares.
I'd be willing to bet that with taking care of the workmanship issues (issues I would fully expect if my serial number was "3") and fine tuning the adjustments with the setup, you can achieve better results.
I'm quite sure there is another side to this story and regardless of your experience, there are about 3 people in a 1000 mile radius of me that I would allow to work on my truck, Bob is one of them and the other two aren't in the business of working on trucks.
i'll gladly show u the 20 some odd emails that were sent to bob. As for tightening the fittings sure as for fixing the hole in the casting sure. As for fixing the hole in the tubing where the weld busted through sure. I might as well do it all over again. We have an quick fix boot and several issues as far as the product not only performs but maintains itself i just wanted to post the facts. Now if you don't believe it why don't u go ask mike S 1 and see what he says. I've already posted lockners email where he states he was disappointed in the dyno results so i'm not gonna try to sway anyone. I've talked bob up on this forum more then anyone go read the posts. It has been kept quiet out of fairness to help them come up with some plan to address it and after 5 weeks with no resolution it's time to hold people accountable. I'm not trying to change your opinion of anyone but i was bragging about being the 3rd set right up until the dyno day. Go check out the other thread "dtt twins to win" then look at the last post it was the day before the dyno run where both mike S and i were there. That's the truth i have a stack of emails that were sent to bob right in front of me. I also gave 2 written requests to put the truck back the way it was and give me my cash back. They weren't acknowledged even though i kept from bashing them for 5 weeks. Is this how a new product is supposed to be, for 6K no less. Then i'm to go back and redo it all in about a month. If that was the case then I would have to rip the transmission about 4 times over by now.
