Harry, when you do the install, be sure to add a drain plug to you pan, or better still, replace the oem pan with the Mopar performance pan or the Mag Hytec unit. With a drain plug in place, you will find it simple and convenient to drain the pan, then drop it if necessary to make adjustments to line pressure and throttle pressure. The throttle pressure adjustment with change the light throttle shift points, while wot shift points are adjusted with care at the tv cable under the hood. The DTT instructions are very good and well illustrated, or if you prefer, call DTT directly for their expert advice.
98. 5 24V QC 4X4 AUTO, 275'S VA, PE, DTT TC AND VB, PSYCHOTTY AIR, BOOST AND PYRO GUAGES, AEROQUIP
FUEL LINES BY V. M. , ESPAR HEATER, 2" SUSP. LEVEL, 255/855 DUNLOPS, AMSOIL FLUIDS.
