Is it possible for an Edge EZ to go bad?
I put one on my truck about a month ago and everything was fine until just the other day. While cruising on a flat highway,unloaded, at 65 mph the truck was "surging" a little. It almost felt as if I was thumping on the throttle, but I wasn't.
I changed my fuel filter and even swapped in my spare lift pump. My fuel pressure would drop a lb or two evey time it surged. Neither of these helped. Then I reverted my truck back to the stock configuration and prest-o-change-o, it was cured. The EZ was on the factory setting. So, I set it to the lowest level and it runs fine there. What gives?
Anyone have any luck actually talking to a person at Edge? Over three different days, I left several messages and spent about an hour on hold.
Thanks,
Ian
Thanks,
Ian
