Engine/Transmission (1998.5 - 2002) edge j fuel pressure sending unit with fass
installing juice fuel pressure unit but my fass has no test port on the fitting. Just barbed on one end, so the replacement from edge wont fit the rubber hose. does anybody make a t fitting with barbs on both end that will fit the dge sending unit? or a banjo bolt?
sending unit working
didn't find anything at napa ,so i called our mechanic. he sent me down to a hydraulic hose shop no luck there but that guy sent me to a specialty hose shop. I was like a kid in a candy store. they had every kind of hose and fitting imaginable. spied some of that blue silicone inter cooler hose there. Maybe next time. they also make custom brake lines for the race cars and had all kinds of performance hoses and fittings. the t block and two 3/8 barbed fittings set me back $ 7. 25 not bad! juice is hooked up and working! Gauge says 16-17 idling. i will have to hook up a mechanical to see how close it is. I know there is a port on my 150 but the edge wire is only about 2-3 feet long so i was looking for some thing that would reach it. I was rereading the fass instructions and forgot that you can tap into the block and run antifreeze through it to keep from jelling --cool
