Edge juice with attitude vs pillar gauges
Slower stall speed tc or not?
Amsoil Bypass?
I like the monitor, lots of different options on what/how to look at. I do boost, EGTs, Intake temp, and barometric pres.
Juice Atiitude gets my vote! Easy install and great warning system too!Oo.
While were talking about Juice/Attitude... how do you change what is shown on your monitor screen. My screen shows EGT, Tran temp, fuel psi, and boost. Can I change what 4 things are on my screen at any time? Also any second gen. users does the Juice show when TC is locked on 1999? Hope these questions arn't too far off origianal post subject.
I went with the analog gauges on the a-pillar, guess I prefer the looks of them. I have considered changing them over to a dash pod and also getting the electronics, would have the best of both worlds.
I kind of steered away from the electronics because they derrive information from sources that feedback the programming of what the ECM says the parameters should be, I do not know if they are actuals, realtime data or some variation of programming. Since we know the oil pressure and temp gauges work that way, maybe some of the other data would be of the same nature? Then if that IS true, the data you see is not as realtime as the analog data would be.
CD
Since I don't know anything about your truck it is hard to answer your question. Fill in your signature for more complete answers. The Juice w Attitude for your truck may not have sensors for things like fuel pressure and trans temp, both of which are very important if you tow, race, plow etc... . You will probably want the Attitude which is a great product IMO, as well as a couple mechanical gauges to monitor everything you need.
