Archived Electric system dead
Archived Stuck in limp mode. 1753
Archived 98.5 starting problem with a twist
Hi all
I have 93 w250 165000 mi. My electric system is completely dead put charger on battery makes no difference power does not get into system. Where should I start
Joe
Drive side inner fender well right in the middle, you will find a bundle of wires from the positive battery post that split into multiple circuits. Those are fusible links that will burn out form load, a short, or just time. Start pulling each circuit apart from the harness to isolate and make sure it is not bad. You can replace them will new fusible links are wire an aux fuse block in to replace the system feeds.
