Just added fuel pressure gage thru the geno cap, pressure is 8psi at idle. As I was testing the gage I noticed the check light was on, looked for codes(3 on and last left at run), no codes.
The only thing I can think is that I bumped something or as I was looking for power on the switch I upset somebody. I did pull some fuses and the one marked diesel transmission was pulled when I restared the truck. I may have pulled others too, could this be the problem? The trucks runs normal and all the gages are normal and all of the fuses are back.
I did the search and I am not sure that helped, except don't take it to the dealer.
Should I just run it to see what gives? I have all my wiring fused so there should be no danger of a fire. The voltage did not come up to center of the gage and that was a concern, but I have not been watching it.
Any suggestions will be welcomed.
Dave Mc
