Have a very good friend with an 04.5 3500 DRW 4X4 automatic & his situation is as follows. Over the last several months when he gets in his truck to go somewhere for the first time that day, @ some point it just takes off full throttle on it`s own. This beast is like a run away freight train until he stands on the brakes. At that point the RPM`S drops & sounds like it`s not even running & throttle pedal does nothing. All of a sudden the tachometer pops back up @ about 800-1000 RPM`S & it runs normal after that. This always occurs before the engine comes up to operating temperature & never has done this after reaching operating temperature. He dropped it off @ a dealership & they told him it was the lift pump & they installed the in tank version. Still does the same thing as before, he had it back over to the dealership & they can`t tell him what`s going on even though he has spent about $2000.00 with them to fix it. Several weeks ago when it was in the low 20`s one morning, he started the truck to let it warm up before he left home & after a few minutes he heard the RPM`S sky rocket, had to run out of his house & cut the switch off as it was sitting there running @ 3500 RPM`S. He bought this truck new & doesn`t want to get rid of it, but this thing has him kinda shook up with the way it`s acting. He`s had enough of the surprise 7000lb rocketship rides. Thank you in advance for any & all help that anyone out there can offer.
