My Pacbrake uses the vacuum pump already on my '96. so, just a solenoid, a switch to activate, a switch behind the gas pedal, and the exhaust brake itself.
IMO a good torque convertor lockup switch REALLY enhances the engine brake experience.
If you don't have a TC lockup switch, and you're driving along with the E. B. switch on, and you release the gas pedal, the TC stays locked up, the EB comes on, and you slow down. Let's say you touch the throttle and then release the throttle. The TC came unlocked and you don't have any EB; as a matter of fact the trans is just freewheeling. The only way to keep using the EB is to depress the throttle far enough, and long enough, for the transmission TC to lock up again. I find that unacceptable on steep downhill grades; depressing the throttle while you're trying to maintain a speed or even slow down just doesn't make sense.
If you DO have a TC lockup switch, and you're driving along with the EB switch on, and you release the gas pedal, the TC stays locked up, the EB comes on, and you slow down. You can touch the throttle and release again; BUT the TC stays locked up. So you're slowing down again with the benefit of the EB.
If you're skilled with the throttle and don't mind having a delayed response (waiting for TC to "relock") then you'll be okay without a lockup switch.
If you want maximum (IMO) convenience and effectiveness, consider a something like the BD TorqLoc (that is what I have). There are better options for the newer transmissions.
In my '96, the EB and TC are unable to slow me down, downshift, and continue slowing me down. With the '96 setup I have, the EB will work in the gear you are in and that's it. With my dad's '06, you can take your foot off the throttle at highway speed with the EB on; it will slow you down through that gear, disconnect the EB, downshift, reengage the EB, and continue slowing you down. To the best of my knowledge, due to the relative lack of computing power in the '96 transmission, ours won't do that.
I just wrote all of this and reread your post; you have a manual trans. Oh well, I'll post anyway because some of what I wrote may be useful.
KRS
