EZeis
I know there is nothing wrong. You’re confusing the exhaust brake function with TH function. The brake itself is capable of the same retarding power as that is only a function of vane position and rpm, nothing else. TH will have a more aggressive downshift schedule and hold the torque converter locked longer, but that doesn’t mean the brake is making more retarding power it just means it’s more usable, which is great with a load and annoying (for me) when empty.
I will go on to say that if you think it’s pointless to run without TH then there is something wrong with your truck, as it’s very beneficial. It’s does feel different than in TH but it’s still very usable, especially in conjunction with CC for speed management downhill.
Dads 17 works identical to my 18, they work as advertised and designed. Nothing wrong, just you’re interpretation of what’s actually happening when you engage TH.
I’ve run TH lots and know the difference, as well as what creates the difference. The brake isn’t programmed different in TH, just the transmission. This is my point that you’re missing.
It would be nice if activating the EB would change the lockup schedule, but not the downshift schedule.
I ran both a Jacobs and a PRXB on my 05/NV5600. They both worked similar but a little different. The PRXB was much stronger below 2000 but the Jacobs was stronger above 2500, but that’s not a normal condition. The cam I had would run the back pressure up over 75 on the Jacobs where the PRXB stayed at 60. More pressure means more braking.
Not at all. You're not understanding the TH runs higher rpms for stronger braking. Exhaust brakes work on cylinder pressure and the higher the rpm and the lower the gear, the stronger the braking. It's so simple. So running the TH does provide significant night and day braking. We can argue this every day for the next 20 years if you'd like. It's just how exhaust brakes work.
My truck is good to go. Yours definitely has an issue if exhaust braking performs the same with and without the TH enabled. Is your PCM and TCM software current?
Do a test, pull up your exhaust braking horsepower and report what your highest braking hp is with TH enabled and disable with braking on the same road and conditions. You should find in the lower gears where with the TH enabled will be higher than vs disabled as the rpms won't hold when TH I'd disabled. If you don't see a difference, you have an issue. You should have a lot more engine braking with TH enabled. With it disabled, you just don't hold the revs. Exhaust brakes rely on high rpm to be fully affective. High rpms and lower gears really brings on the braking power. That can only be fully achieved with the TH enabled. I prefer the exhaust brake to do most of my braking. Wish the torque converter could stay looked at lower rpm. Do miss my manual trans truck with the pacbrake as it would brake down to idle. This truck kicks out at about 18ish mph and you're like crap. Took me a long time to get use to no exhaust braking below 18mph. Even to this day I sometimes get caught off guard by it.
Earl
