sounds good
Doug, I agree. The testing should be done with an "as is" attitude. Whatever is in the box for the "regular joe" that buys the system is what should be installed.
I am concerned about a few things though. One, is the fuel pressure. I think it is important for a mechanical gauge to be installed as we should know what the stock system was and what the preporator system is out of the box, so we know. There is a pressure difference between the (12valve 24#, and 24 valve 15#) motor, so I believe it is a factor in this test.
The only other thing that "I" would want to know is the volts at the pump, both stock and with the preporator. If there are any chances that a relay is involved to try and turn the preporator pump harder/faster would, to me, be of concern.
Trying to turn more than the required 12 volts in a system also has a factor in longevity for the pump.
One last thing is this. The testers here, you, Wade and Kevin should be the ones to set the rules on the dyno rules. Along with input from those of us following this on the TDR. I wouldn't want Charles to dictate to you how the test are to be done so as to better his position/system some way that we don't know of.
of course... ... ... just my . 02
Don
