I have had the FS 2500 installed on a 08 6. 7 for about a year and the soot is still there,maybe not as much as before but,
I did a sample at 5000 miles and it said the oil is within normal parameters,I have the exact analysis in a file here . Valvoline True Blue 15w40 CJ-4 13. 5 qts.
FS rep. says that the 6. 7 soot particles are to small to be completly caught in the filter. Now it takes 13. 5 quarts to fill it up and now i have noticed my oil levels on the stick rising slowly? As mileage increases, Is this caused by fuel dilution as it now shows overfull on the stick when i check it whren the engine is cold after about 5000 miles.
And it was a *** drilling the holes in the frame rail for the mounting bracket as there is not much room for a drill and short 1/2" bit up in the frame rails lucky i had a right angle drill. the hoses could have been a few inches longer as i had to tie wrap them up to keep them away from the turbo heat . Route the hoses first before drilling the the filter mounting bracket .
I have found that the right angle fitting on the oil cap return line will rub a notch in the 08 hood blanket and engine movement will rub a hole in it eventually .
I have bought a small piece of Foil Faced "Dynamat" from a stereo electronics store and stuck it up there. it looks good and protects the hood blanket.
Anybody Buy any of these 2500 filters in Bulk i need to buy a couple more ? and a spare fuel filter too.
Also seeing new fuel filters on the market on Ebay that are selling at 16. 00 bucks and do not have the canister with them. Are they worthy or should i just stick with the fleetguard mopar solutions ?
Austin Diesel
Austin Diesel
