WOW!!!
No wonder you were scratching your head. You did well to find it that quickly.
Speaking of things that make you scratch your head. .
We sold several M2 trucks to the local utility company. 6. 7 Cummins with an Allison Transmission. They have had these trucks for at least 2 years.
One came in last month with a complaint of the transmission getting hot (they have trans temp gauges from the factory). Tech crawls under the unit and decides to inspect the transmission cooler lines and cooler.
Guess what..... there were not any lines to be found. Neither the pressure or the return lines were there.
Upon further inspection found the cooler ports in the radiator still plugged with the plastic shipping protectors that the radiator had in it when it was shipped to the truck plant.
Upon even further inspection he found that the plastic shipping plugs WERE STILL IN THE ALLISON COOLER PORTS ON THE TRANS BODY ITSELF... ...
So those plastic plugs withstood the pressure and heat generated by that transmission for over 2 years. I would not (with my luck) have been able to drive something like that 10 feet without all Hell breaking loose.....
The truck was supposed to have the cooler lines, they just got missed when the truck was assembled. They were in the build record and parts listing, just never got put on.
Mike.
