Bluebird
Message center ABS, and brake warning lights started coming on, truck started shaking during braking above 35mph, warped rotor type vibration upon braking. Took her apart to find 75% on pads even both sides, in/outboard, however right rotor outboard slight grooves. Decided to replace pads anyway, emory papered the outboard with a large socket as a sandblock, used wire brush on drill to clean-up. Reassembled all new hardware/clean. Test drive: slight vibration braking above 35mph, quickly disapears. When at idle, message brake warning/ABS lights on, but will go off with small increase in RPM's. I wiggled some of the vacuum hoses at idle the message lights went off
Any help is appreaciated
Happy Holidays to all of TDR members/readers. TDR the best resource known to man:-laf,
Patrick.
Patrick.
