Fuel Pressure Gauge Suggestions
Back-up Lights..revisited
Who makes the best gauges
I am going to be adding gauges soon, and was set on the VDO's for Boost and Pyro, but VDO does not make a fuel pressure gauge. I am at the point now of thinking that fuel pressure is more critical than boost or pyro, at least for us stockers. (Just reading the lift and injection pump failure posts makes me cringe) Would really like to have a set of three matching gauges. Will be buying a 3 gauge pillar mount, and I can't think of anything more important than a fuel pressure gauge to stuff into that 3rd hole.
I have thought of the SPA digital, but I did not see a dual fuel pressure gauge listed. A pre and post fuel filter pressure reading on a dual display gauge would be kind of neat. .
Any thoughts from the group would be appreciated.
Shelby
2001. 5 2500 QC LB 4WD, ETH (Built 09-10-00), DEE, 3. 54 gears, Laramie SLT, Camper Special, Trailer Tow, Travel Convenience Group, Power Driver Seat, Alarm System, Remote Keyless Entry, Fog Lamps, Cab Clearance Lamps, HD Transfer Case, Bright White with a Gray Interior. Built 09-15-00, took delivery on 10-06-00, 3873 miles as of 01-04-01. Custom aluminum work body / flat bed. Coming soon: E-Brake and gauges.
Shelby,
I do not believe that SPA makes a dual gauge that is labled as fuel press/fuel press. I believe the gauge that everyone is using for pre and post fuel pressure is actually their dual pressure (brake bias) gauge. The part number for that gauge is DG-105. They do make a number of dual gauges that have fuel pressure as one of the two readouts. You can see all there gauges at http://www.spatechnique.com/instruments.html
If you decide on SPA's remember that they are dual gauges, so boost/egt is one gauge. You would only need a dual pod for this and the press/press gauge.
Hope this helps.
John D. Rathert Jr.
01 2500 SLT+ QC LWB 4x4 Auto 3. 54 rear end, Forrest Green Sport with all options avail. DC Nerf Bars, DC Grill Gard, DC mud flaps, Line-X bed liner, Leer 160XL Topper, Power Edge, EZ Edge, SPA Boost/EGT Gauge on pillar mount, DDT's torque converter - valve body combo, 275 RV injectors and Diesel Dynamics 4" Exhaust.
Airbox Mods, new turbo and SS fuel lines in planning stages... .
See My Truck
Dads truck: 98. 5 3500 SLT QC LWB 4x4
Brother Truck: 92 W250 SLT CC LWB 4x4 (Dads old truck)
See 5 Diesels and a Gasser
Winter fun: 2000 Skidoo Summit 700
FREE HVAC!!
Edited twice so that it would make sense... .
[This message has been edited by JR2 (edited 01-23-2001). ]
Shelby - I see some folks running a single guage that is switchable (in the cab) between 2 sending units (Pre and Post filter).
Shelby,
I installed the Autometer Ultralites. The gauges are extremely easy to read and the gauge lighting color matches the original. You use a green colored boot for this. I drilled and tapped the bango bolt which goes into the injection pump. The gauge works great!! Let me know if you need any help.
2000 24V, 6-speed, Flame Red, Agate leather, 3500 QC, 4X4, SLT+, 4:10's, LSD, AMSOIL Air/Oil filters and all Fluids, 275 RV squirters, S. S. nerf bars, Line-x, Autometer Ultralites Pyro/Boost/Fuel Press gauges, MOPAR tow hooks.
Shelby,I personally don't think pre & post filter are necessary. With just a post filter gauge and new filter you will find what your pressures run,when they start to drop it's time for a new filter. Tapping the injection pump banjo bolt is probably the best way to go,it's sturdy and the sender & wiring are out of the way for other maintenance. One thing the 24 valve has going for it is the low fuel pressure, makes it easy to find a gauge with the correct range. On a 12 valve the pressure can reach 30 psi,mine is usually 22 psi. Most gauges jump from 16 psi to 80 psi,neither range is appropriate for a 12 valve.
