Engine/Transmission (1994 - 1998) Fuel solenoid problem
Engine/Transmission (1998.5 - 2002) fuel additives
2nd Gen Non-Engine/Transmission AC issue
My fuel solenoid does Not activate when the temperature is low enough to heat the air in the manifold. It will hold and start and run if I reach in and pull it up manually. Everything works fine when the ambient temperature is high enough.
I recently replaced the solenoid and relay. ???
Thank you in advance Skip 1996
My truck is a 1996 with 289,000 miles and no modifications. I have been the only driver with very few problems.
