The larger of the two relays on the firewall is the fuel solenoid relay. There is only one relay involved. There is a dark blue wire on the positive post of the driver side battery. If it is loose, corroded, or broken that would cause the same thing. You might want to email me at -- email address removed -- for my 12 valve fuel supply system write up. It has pictures of the things involved in this problem.
