On the other hand, my old 2002 Dodge/Cummins,
does nearly identical dyno numbers at the REAR WHEELS. Not all that much done for those numbers - and still the lower displacement, NO DEF - plus 27 mpg out on the road empty, 17 mpg towing our 24 ft. 5er...
Not too shabby for a $30K truck thats 17 years old...
Newer is sometimes better - but usually at a fearful price...
If only vast HP/TQ numbers satisfy, spend $15K less, and make a few mods - then, what a surprise to the big buck guys as you blow by them on the grades towing your own load...
Has anyone noticed in the pic above, how the engine is still quite accessible, and easily serviced or worked on...
'02 HO Quad cab 2500 ETH-DEE, 6-speed manual, all extras except leather! Could these be the LAST of the "real diesels" from Dodge/Cummins...?
E
dge comp, BHAF, Frantz oil/fuel filters, Don M 1.6 FI injectors, Rip's 4 inch exhaust - pillar mount boost/EGT and fuel pressure - coolant bypass filtration system - Walbro 392GSL
fuel pump - DSS stainless
intake tube - Amsoil/Donaldson 4510 air cleaner...
