Thanks, yeah going to do at least 500 try for a 1000 miles city driving before I hook the trailer behind it. Right now it feels like clutch is dragging a bit engaging gears and shifting, nothing like before. Maybe it’ll go away as the clutch wears in or I may need to adjust the rod on the clutch cylinder. Any thoughts ?Unless you’re hot-rodding or have a substantial amount of HP over stock the clutch you have will serve you best. Pedal pressure doesn’t have anything do do with holding power with the clutch you have. Make sure you break it in properly and you’ll be very pleased.
