Gauges and 16cm housing installed...
Any leads on a single aluminum wheel?
Headlight Problems (more) Help
... well, almost. Still need to install the trans temp sending unit and hook it up, and cut my dash mat to fit around the pod, but everything else is done. All I have to say is..... what a pain!!!!:eek:
Had to remove the turbo from the truck to get the housing off - couldn't get a good swing with it still in place. Secured it in the vise, used a longer bolt and a piece of 1/2" flat steel to get it moving, then a BFRM (big friggin' rubber mallet) to get it off the rest of the way. Didn't give me too much of a problem - whacked on it a few times and it didn't budge, but once the bolt broke it loose it only took a few hits and it was off. :)
While the turbo was off I drilled and tapped the exhaust manifold for the thermocouple. Other than taking about four tries to get the hole tapped the right depth - didn't want to go too far;) - it was pretty simple.
I used the existing plug in the intake manifold for the boost gauge - didn't have to drill or modify the bracket like some people have... maybe that's only an issue with the non-intercooled trucks???? I overtightened the fitting and crimped the plastic tubing the first time, so I had to make a run to Ace for a new ferrule (or whatever that funky little brass ring is called).
The real ordeal came when it was time to run the wires and tubing - I hate working under the dash! I was a little hesitant to drill a hole in the top of the dash, but really didn't want to run the split loom down the front... yeah, I'm picky. ;) I finally got everything run and hooked up, losing a few ounces of skin in the process... not to mention the aches and pains from trying to fit my body between the seat and brake pedal, cram my arms up under the dash, and do my Exorcist impression trying to see what the heck I was doing - skipped the projectile vomiting, though. :D Did I mention I hate working under the dash? I also found out that a 60-watt bulb in a metal-shielded drop light makes a great branding iron. :eek:
After putting the dash back together and stopping any major bleeding, I took the truck out for a short ride to see what the gauges said:
Max boost: ~17 psi
Max EGT: ~950-1000*
Boost at 75 MPH cruise: ~4 psi
EGT at 75 MPH cruise: ~700-750*
I was really surprised at how fast the EGT reacts to any change in throttle - heck, when I started the truck and it jumped to just under 200* I was wondering if I screwed something up. After driving it a little I'm pretty sure my readings are within the normal range. The 16cm housing did seem to make a noticable difference, but I'll have to wait until I drive it a little more to know just how much.
The biggest bummer of the day is that I wasn't able to track down the #$%& rattle I have somewhere under the dash or firewall area. It's been driving me nuts for the past month but I can't figure it out. Pretty bad when the rattle is louder than the stereo..... :{
I'm not sure what to do about the trans sending unit. The "T" fitting I bought is too wide to fit between the lines, so I'm considering installing the new sending unit in place of the factory one. As long as I keep an eye on the temp gauge and kick it out of overdrive when appropriate I think I'll be fine. The only concern I have is whether removing the factory S/U will cause the transmission to not shift into OD.
Anyway, here is a pic of the gauges installed - the pod is from U. S. Gear.
(Hmmm... for whatever reason, the pic isn't showing up. )
gauges = kewl, ja?!
Dan, great post on your gauges - boy does it sound familiar! I'm gald you got 'em all in and working (save transmission). I'm with you on the wiring all inside. I like 'clean'.
On your trans sensor, have a look at my readers rigs, diesel. There are a couple pics of my trans temp sender installed. I use the factory and new one together, via a male-female-female T fitting from local parts store. Worked slick and simple.
WARNING - when removing and reinstalling the transmission sensors USE A PIPE WRENCH to hold the factory sending unit BUNG, not tube, in place - he factory outlet transmission cooler tube has the sensor bung welded/brazed to the transmission cooler line, and it's WAY fragile - too much wrench and arm power without holding the BUNG in place may actually rip the bung off the tube or totally twist the tube all to hell.
My transmission temps are about 5-10* cooler than the engine usually. On hills it comes up a bit. My engine runs at 160* and the transmission at about 150* all the time (unloaded/empty/highway). Actually, towing on flat and level doesn't change temps much. Hills are another story.
Also, your readings are pretty much right on the money.
Laters,
- Sam
Sam - Your pics are what gave me the idea to use a "T":) - unfortunately the only one I've been able to find so far is a 3-way female and too big. :( If I would've been thinking I would've done the shift lever/OD switch at the same time. Oh, well - at least I know how to get the plug loose from the message center now. :D
Forrest - I'd like more fuel but I'm still a little hesitant to mess with the pump. Injectors would be nice, though... too bad the PWs are so expensive now. :(
don't sweat messing w/ the pump... I turned up the pump on my '91. 5 using the instructions on dodgeram.org... I turned it up at about 235k miles... it's still running strong for the previous owner at over 375k :D
if you get injectors, go for the gusto and get the POD's!! :D
but seriously, I'd at least turn up the pump a little...
Forrest
Kewl dude - hey, that column lever 'job' only requires taking the steering column covers off - dash stay in place - woo woo!
There's a thread on it somewhere with all the details, part numbers, etc. I'll try to find it and repost or beam it to you - computers and me are on a love-hate relationship. When they work I love 'em. When they don't I hate 'em. And when they're smarter than me I wanna throw 'em out the window ;)
- S
Forrest - No PODs for me... the smog Nazis around here don't like smoke. I'm not crazy about fogging for mosquitos, either.
Sam - I have the thread bookmarked, along with a great write-up that Rodney emailed me with all the part numbers. :) I just need to find time to go to the steal... . er, dealer to order the stuff.
Don't get me started on computers - I have less patience with them than I do for vehicles... . :p
Dan,
That dash pod is one sweet setup! Your numbers pretty much match mine. I never knew what they were before I put the 16cm on, so I don't know the change.
Where did you get the gauge pod? And for anyone else reading, is your map light broken from it's bracket? Both of mine were when I bought them. Just wondering if everyone's is that way.
Ok then,,,, dan gets the "Star Of The Week" award for that very entertaining and desciptive post..... gotta luv it don't ya... :D:D:D
There's a 5 RWHP bonus for that one guys..... :D
Pastor Bob...
my philosophy is: "real diesels smoke" :D
but, you can turn up the fuel on the pump and never see a puff, and I think you'll be quite pleased with the difference in performance... won't give anybody white knuckles or anything, but it'll make it feel like a new truck! :)
Forrest
tugboatphil - I bought the pod from U. S. Gear. They have three and four gauge pods - probably two gauge as well but I didn't ask about them. Here are the part numbers:
3-gauge
DC-6530 Base and DB-5930 Dome (I paid $46. 00 plus shipping for both pieces)
4-gauge
DC-6540 Base and DB-5940 Dome
My map light isn't broken... yet. ;) I've had it out to replace the stereo, and now to install the gauges, so I'm kinda surprised it's still intact. The previous owner tightened the screws for the headliner trim tight enough to crack the plastic or strip the holes, so that makes it even more shocking. :eek:
Bob - Glad my misery could provide some entertainment for the rest of you. :D I'll take the 5 HP bonus, too - I need all I can get. ;) What do I need to do to earn a limited slip bonus? One wheel drive sucks. ;)
Forrest - I'll see how the truck feels with the Jeep hooked up, and if I need more power;) I may do a little tweaking. I just want to make sure I don't hurt the reliability or have problems when I go for the yearly tailpipe probe. :eek:
Another bit of info for anyone interested: The paint I used for the gauge pod is "SEM Color Coat Flexible Coating," part #15303, graphite. It seems to be a pretty good match, at least as far as I can tell with my lousy color vision. :D
can pretty much guarantee you that you won't have any problems w/ the "probe". it's also VERY easy to readjust for "testing[/QUOTE
I would agree... . I had to go for an emissions test a couple of months ago... first time with this rig. I "de-tuned" before the test, but I don't think it was really necessary... the snap test they did was wimpy... I got like . 5 out of a possible 40.
Next time I'll get tested with full power, because I know I can always clear the free re-test with a 5 minute de-tuning.
Jay
Yeserie!
You can't beat the puncture wounds and utility light burns... ..... A solid two week reminder that I "did it myself" :rolleyes:
Greenleaf
