Its been getting worse and worse over time. It started off by taking longer to get started like dads' '03, but now it won't start when its hot. When it is cold, it doesn't start instantly like we are all familiar with, but it will start. After it has been run, it cranks and cranks for as long as you'd like. Funny thing is, the other day when it wouldn't start, I let it cool off and kept trying, finally I gave up called dad to come and get me. Just for the heck of it I tried to pop-start it and it fired right up.
I've figured that its air getting in somewhere, so I made sure that all my lines were tight, I also took off my fuel pressure sending unit to eliminate the possibility of any problems with the rubber hose that feeds it. I also changed the fuel filter to make sure that it wasn't restrictive at all. Fuel pressure has been a constant 12-14psi. I've been second guessing myself and my installation of the 366 spring, which brings my to my second and possibly related problem. When you let off of the clutch, it is weak. Not really being able to type exactly what is happening I'll put it to you like this; usually you can slip your foot off of the clutch and the truck would go. Right now, if you aren't careful, it will stall, even the exhaust brake bogs it down. It seems to me like something is wrong with the govenor, which leads me to believe that I did something wrong with the 366 spring install.
Who would of ever thought that an old worn-out farm truck with 311K would be more reliable than a 2wd cream-puff. :-laf Tell Jermey that one Philip.
Oh, and by the way, once you do get the truck running, it runs as strong as it ever has. I hauled a tractor 3 weekends ago, the biggest hills that I came to couldn't stop it.
Thanks everyone.
