hardwired ez on a 02
Clutch went kaboom
spring loading or axle wrap
well i did it and it works well, no mil lamps, fellers at edge were happy to hear it worked fine. They are working on adaptors to make the EZ in the EZ... ... ... . but the thing rocks
i will post a schematic if there is interest... ... ?
Brandon
2002 Wiring Harness
So Brandon, which connection did you have to hardwire??? Was it the MAP connection or the data port???
I'm sure Edge is working to obtain the connectors for the new configuration.
Please Keep Us Updated!
Those of you that have contacts with PE, please keep us updated on the progress being made on the Edge EZ for the 2002. I'm sitting here having purchased an EZ for a 2001 this summer when I ordered my 2002 - this thang ain't doin' me a lick of good! :rolleyes:
Rusty
P. S. - HVAC, it's the MAP sensor connector that's changed on the 2002's. The connector is larger, more rectangular in shape (vs oval) and the pin spacing is wider. :(
good job Brandon--when we talked about it the other day I wasn't sure if you were going to do it or not---again good job and glad it worked... . chris
