Headlamps, but no running/parking lamps?
2004 cb install
Trigger wire for aux lights?
My radiator blew a gasket last week, so I took it to my mechanic to replace the radiator. When I went back to pick it up, I had dead batteries and needed a jump. Somebody either left my amp on, or accidentally bumped the switch.
Either way, we jumped it and I turned the lights on to head home and "bam", headlights, but no running lights. No fender markers, no cab lights, no tail lights, no nothing. I flipped on the 4-ways and headed home.
I have 14. 4v to the fuse block, the fuse is good, no codes, wth???
EDIT: I switched the park lamp relay with the starter relay to rule that out ... ... ... . switch maybe?
JHardwick I have pretty much the same problem on my '98. It started when I went to turn on the headlights and the switch malfunctioned and sparks went flying. No taillights, running lights, markers, no dash lights.
I thought a new switch would fix the problem but no, same problem. All the fuses are fine, no problems with the electrical connector. I have been able to determine all the lamps are good because if I hold the headlight switch in just the right place I can get them to come on.
Just unplug the headlamp switch. As soon as the controller sees the input is missing it turns on the lights for safety. That tells you if it is switch or controller.
Well, it wasn't the switch ... ... ... ... luckily the dealer let me run out to the truck and try it real quick before I bought it, but the mechanic standing there had no suggestions :(
After coming home and poking around on here, and sifting through the service manual, I decided to call back down to the dealer and order a FCM. He has one on the shelf for $173, but are closing early for the holiday. I'll head down Friday morning.
I think you're on the right track. I have been reading about FCM failures in the magazine- which I'm not happy about and I believe that controls everything.
BTW How many miles do you have now?
At this point i think I'd take a close look at the radiator replacement and see if a wire was cut or left loose since it happen right after you had it replaced
I talked to my mechanic just a little while ago. He said it was pretty much a straight pull, but he'd look at it if I wanted him too. And after removing the PDC today, to replace the FCM, I'd have to agree.
I think I need to bite the bullet and have Dodge stick the DRB-III on it as much as I hate to.
Unfortunately this is the only real way, along with the Body Diagnostic book...
DIAGNOSIS AND TESTING - FRONT CONTROL
MODULE
The front control module is a printed circuit board
based module with a on-board micro-processor. The
front control module interfaces with other electronic
modules in the vehicle via the Programmable Communications
Interface (PCI) data bus (J1850). In
order to obtain conclusive testing the Programmable
Communications Interface (PCI) data bus network
and all of the electronic modules that provide inputs
to, or receive outputs from the front control module
must be checked. All PCI (J1850) communication
faults must be resolved prior to further diagnosing
any front control module related issues.
The front control module was designed to be diagnosed
with an appropriate diagnostic scan tool, such
as the DRB III. The most reliable, efficient, and
accurate means to diagnose the front control module
Fig. 5 INTEGRATED POWER MODULE MOUNTING
TABS
1 - INTEGRATED POWER MODULE MOUNTING HOLES
2 - BATTERY TRAY ASSEMBLY
3 - FRONT CONTROL MODULE
DR 8W-97 POWER DISTRIBUTION 8W - 97 - 5
INTEGRATED POWER MODULE (Continued)
requires the use of a DRB III scan tool and the
proper Body Diagnostic Procedures manual.
Before any testing of the front control module is
attempted, the battery should be fully charged and
all wire harness and ground connections inspected
around the affected areas on the vehicle. "
From 8W-97- 5/6 in the FSM... .....
Well, the only dealer in the area open Saturday morning scanned it and said it was either the PDC or the instrument cluster. I'm betting PDC and they quoted me $425 for a new one. I called my regular dealer this morning and they want $301, but it's on national back order :{
