heater cluster replacement bulb
19.5 Dually Wheels "American Force"
Brake Dust
Does anyone know what the part number is for the heater/ a/c cluster bulbs are? and if the is a common replacement or if its a factory part. . thanks
You will have to go to the dealer, I purchased replacement LEDs and half quit working a couple of months after installing them. I ended up going to my local dealer for the stock bulbs.
5013815AA is the Mopar number for the bulb.
That is a dealer item. They should have them right in stock and it takes 3 total. You might as well change them all while you are at it. :)
Mike.
How hard is it to replace the bulbs in the dash? I also think I have a bulb out behind my tachometer. How difficult is that one to replace?
I removed the panel below the steering wheel then backed off the two nuts(13mm) on the bottom of the steering column (NOT ALL THE WAY OFF). Remove the headlight switch (should pop out from dash) removed the two screws holding the speedo cover bezel, it will pop out with a little work, You will need to remove the heater panel so you can get to the speedo screws, then I believe there are 4 screws holding the cluster in. Once you remove the screws pull the left side of the cluster out (NOT TOO MUCH) just enough so you can reach behind the cluster and disconnect the three multi pin connectors. The speedo should slide out. You might have to tilt the steering wheel all the way down. Good luck and sorry if this was too long.
