Just replaced the head gasket; had the head cleaned, magnafluxed, and milled. Used ARP head studs torqued to 135 ft/lbs and all OEM gaskets to include exhaust, intake, crossover tubes and injector seals. Valves were adjusted to .010/.020. It started right up, idled smooth and drove smooth...until I get to about 32 lbs of boost, then the racket starts. The truck has compound turbos and can push about 58 lbs of boost; it never made this noise before. I tried to see if it was related to RPMs by dropping a gear and running it on the highway at about 2800 RPM, didn't do it. It is directly correlated to boost.
Im workamping and gotta get this figured out so I can get back on the road.
